Help on building A tri powr set up for a SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2007, 10:46 AM
I am currently building 3x2 setup on a 1985 350. i have 3 small base 2gc's and a intake. i have the choke that works off of heat from the exhaust. the one thing that i am unsure of is the secondary carbs. i know you are supposed to have different butterflies in the base but i am not sure. I was wondering of anything else has to be changed in the secondary carbs? blocking of the idle circuits and what not. any help would be appreciated.
Thanks,
Jeff
Old 10-09-2007, 11:09 AM
stea's Avatar
I contemplated the same setup for my sbc, I had a link that showed how to block the idle circuits but I'll be damned if I can find it. I planned on blocking the secondary carbs idle circuits and running a progressive linkage set up. Hunt around a bit and you will find the info needed.
Also make sure the throttle plates on the secondary carbs completely shut. Ive heard its a nightmare to tune if they dont.
Old 10-09-2007, 11:30 AM
Check out this link to another forum:
http://www.clubhotrod.com/forums/showthread.php?t=26886
Old 10-09-2007, 11:48 AM
stea's Avatar
Thats the link that went AOL
Old 10-09-2007, 05:21 PM
Thank you very very much. That was the most usefull information i have gotten since i decide to put the setup on my t bucket. thanks again
Jeff
Old 10-10-2007, 10:45 AM
Hope it will help you. I plan to do the same thing on a SBC in 37 Ford 2 door slantback
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
I'm building a sbc 350 need input PLEASE the ernster Engine 8 07-13-2005 01:56 PM
SBC building advice shatteredmindofc Engine 1 09-26-2004 01:35 PM
Building BIG HP 400 SBC Sampson Hotrodding Basics 11 04-04-2004 12:52 AM
Building a Tri Power Set up western star Engine 3 12-12-2003 11:44 AM
