Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help! Building a tub for a Rat questions...
Old 12-03-2012, 12:28 PM
timothale timothale is offline
Wiki Edits: 27
E book time
click on the eBook tab aat the top of the page , read it then read all of Cboy's other builds. I found some pieces out in the desert, and started on the roadster. I laid out a grid on a sheet of plywood, and use a carpenters square, screwed the pieces to it, make cardboard paterns so both sides would be the same for the sub structure. the other picts are too large to post, I had to make a new trunk lid, upper and lower back, and still need to make the doors. for the doors you might be able to find some wrecking yard truck doors to cut out the pieces, with some contour ... here's a poor pict my son took with his phone when we first started on it. .
