HELP!!! Burnt Distro terminals - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2005, 10:40 AM
interro1's Avatar
Until death does it backfire!!
Not too familiar with HEI but here goes
I pulled the distro cap off and found that my terminals, both on cap and rotor are burnt and there is residue all over the assembly.
Any thoughts?
(edit) I don't want to put the new one in and have it get burnt to a crisp the minute I start it up....
additionally....I don't know how long the other one has been in there.
Old 07-15-2005, 11:44 AM
Jmark's Avatar
Its normal wear for the end of the rotor and the ends of the 8 cap terminals to be badly pitted and kinda burned looking. Time to replace them. A high milage cap and rotor will also burn the center post in the cap and the metal tab on the rotor. Again, just time for a change.
As far as the residue goes, it depends on what it is. If its a copper or redish color, its usually rust dust from the weight pivots. Again, fairly common but wear is not a good thing. A drop of oil on each pin won't hurt anything. A small amount of oil slung around the inside of the cap is common too. Some will work its way up the shaft and get tossed around by the reluctor. Not a biggie unless its really soaked inside.
Mark
Old 07-15-2005, 11:47 AM
interro1's Avatar
sounds good....little oil in there....hopefully there's nothing wrong.
little dust in the weights area....might throw a bit of lube down there too...
thanks for the help...
oh and BTW.....I know you're a Savage fan...thank you for your support.
(I'm active duty...)
Old 07-15-2005, 09:54 PM
johnsongrass1's Avatar
Race it, Don't rice it!
A bad condensor will do it too.
Burnt Alternator Brushes ArnoldD Electrical 3 08-15-2004 11:21 AM
Burnt Points...Hot Coil? wickster Electrical 15 07-20-2004 08:54 PM
Rebuilt 700r4 Burnt in 10 miles subman17 Transmission - Rearend 9 02-15-2004 03:41 PM
almost new 454 with one burnt piston clyde Engine 2 01-12-2003 08:18 AM
hei distributer,burned or dirty terminals in cap what causes this? IHAVECHEVYPARTS Engine 3 11-19-2002 08:32 PM
