Help with cam Choice ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2011, 09:06 AM
BG383's Avatar
BG
The choice(s) at hand.. A crower Roller Cam(00470) specs... 286/292..232-240 @.050...549/559. Im debating on this VS. the XR288HR from comp cam. They have almost mirroring images of each other, except at .50 the duration is shorty with the crower. Does anyone have any EXPERIENCE with THIS Crower cam and how will it perform in a 383sbc with AFR195;10.5 compression
Old 03-02-2011, 09:12 AM
SSedan64's Avatar
The Crower will have slightly less agressive Lobe ramps and may be a little less noisy. Some of the Comp XR's do have unwanted valvetrain noise.
Old 03-02-2011, 10:48 AM
my87Z's Avatar
Veteran/Firefighter-EMT-I CRT
that's what i have heard about the Xtreme energy line from comp as well (a lot of valvetrain noise) i would probably go with the crower cam
Old 03-02-2011, 11:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Seems to me that if the Crower cam has the same lift and less duration, that the lobes would be more aggressive on it than the Comp cam. Am I missing something? Or is it a matter of acceleration being higher w/the Comp cam- and where would this info be found?
Old 03-02-2011, 11:43 AM
BG383's Avatar
BG
the lift and duration @0.50 numbers are different. Here are the specs.... http://www.compcams.com/Company/CC/c...?csid=161&sb=2
Old 03-02-2011, 04:06 PM
ericnova72's Avatar
More for Less Racer
For your particular application I like #00471 better, it only has 4° of split in the duration. Your AFR heads don't need or want that big 8° bigger exhaust lobe.
A big split like that is intended for heads that don't have as good an exhaust port as the AFR head does.
Old 03-02-2011, 07:07 PM
that compcam makes goooood power, the xr282hr is a good cam, matched with some 215 flowing heads, you could see 480hp and 450tq very easy, or more, so with that xr288hr you are looking at, you hit some real good numbers with the rite stuff to go with it!!! , on the other hand the bigger the cam the more air flow you need, like going from 215's to 225's, if i had some 225's or 230's id start with the xr292hr, and pump out close to 600hp lol, no prbs there
SBC cam choice Rhansen Engine 13 10-31-2009 02:46 PM
Cam choice redrod4 Engine 1 01-10-2008 07:42 PM
Cam choice for 406??? 66sedanman Engine 14 09-04-2007 09:49 AM
Cam choice Schoust Engine 0 02-04-2004 11:30 AM
Cam Choice sb72elcamino350 Engine 4 11-10-2003 06:47 AM
