help with cam and manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2012, 08:05 PM
Got a 57 chevy truck 350, .30 over, fuelie heads, 9.5-1 compression, edelbrock 1406 cab, hugger headers, super 40 flowmasters, 700r4 trans. Need help picking intake and cam. Truck is going to be a driver. I have performer rpm intake now but is ther a better choice?
Old 06-18-2012, 08:33 PM
DoubleVision's Avatar
The intake you have is fine. As in a cam tell us what you want. Do you want a lopey idle but still good street manners? Do you intend to stay with the stock torque converter? What's the rear gear ratio?
Old 06-19-2012, 03:47 AM
Going for mileage over hp never going to race truck. Going to be a daily driver that I can have fun in. Would like it to sound good. As for the converter I believe its stock. Have to check on the rear gears it’s the stock axle that came in truck.
Old 06-19-2012, 08:02 AM
So should I go with a eddy performer cam 95% of my driving is going to be under 5500rpm. will this cam work with the rpm intake or should I get the matching intake.
Old 06-19-2012, 08:48 AM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
Couldn't be easier. Find out what rear gear ratio you have along with stall speed of converter you have. Call cam company of choice and tell them what you have and what you want to do.
Will this cam work with this intake manifold. darce Engine 1 07-28-2011 02:44 PM
Cam and intake manifold combo question. Dajerseyrat Engine 5 03-24-2011 02:05 PM
305 cam carb manifold stickshift Engine 6 04-12-2005 03:46 PM
Cam and Intake Manifold for a Chevy 305? Mike_82 Engine 8 10-07-2003 09:06 PM
