Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with cam selection on my 383
Old 10-08-2009, 09:15 PM
glen242 glen242 is offline
Originally Posted by ags111075
Im building a 383 for my 70 corvette,4 spd and 3.36 gears. I have 10.1 compression,performer rpm heads that have been bowl blended,stealth intake,650 or 750 holley dp i have both,headers and flowmasters.I wanted to keep this gear but willing to go to a 3.73.Im looking at the voodoo cam's 60103 or 60104.Thanks in advance Aaron
Part Number: 60103
Hydraulic. The most awesome 268 cam ever produced! Out-powers all others! This High Performance street cam likes 2400 RPM stall, 700 cfm carb, dual plane intake and headers. Makes un-equaled power to 6200 RPM with proper valve springs. If you're looking for a Very Strong cam with great street manners then this cam is it.
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .489/.504
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Part Number: 60104
Hydraulic. Hot Street cam, likes 2800 converter, Hi-Rise type dual plane intake with 750cfm carb, headers, 10:1 compression and 3.73 gears. Likes up to 200HP nitrous.
Advertised Duration (Int/Exh): 276/284
Duration @ .050 (Int/Exh): 233/241
Gross Valve Lift (Int/Exh): .504/.525
LSA/ICL: 110/106
RPM Range: 2200-6400
I am running a CC XE274H cam that is a little smaller than the 60104 (230/236 i think) and it is fine. I would go with the 60104 over the 60103.
Engine is in my '76 'vette 4-speed, 3.36 RA. Engine has the usual mods.
