HELP! Can't get the trans dip stick tube in - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2005, 08:38 PM
Does anyone have any idea how to press the dipstick tube into place on a turbo 350 transmission? Just had it worked on. Put it back in and got a new chrome dipstick tube - (same size as old one but not as bent up). BUT I CANNOT GET IT PRESSED IN!!! If I take out the rubber fitting in the hole then it seems to fit perfectly but I'm reasonably sure it will leak, big time!!! Everything is in place but I cannot seem to get enough torque (or pressure) on the tube to mash it into the hole with the rubber grommet in place. Is there a special tool of any kind? I have very little room to work (headders are close) or get anything on it... This is on a 67 camaro. Any suggestions would be greatly appreciated... It should be so simple..... AAAHHHHHH
Old 11-05-2005, 09:45 PM
Ditch the rubber seal and put some RTV around it and slide it in. Works with an oil dipstick
Old 11-06-2005, 07:42 AM
Crosley's Avatar
Wiki Edits: 1659
there are two types of seals for dip stick you mention.
If the tube has a groove around the tranny end of the tube , a rubber O ring is used.
If the filler tube has a tapered / narrowed end at the tranny end, a rubber sealing sleeve is used. This sleeve MUST be installed into the tranny case FIRST , then the filler tube slides in. Lube the filler tube end with tranny fluid or some thing similar
Bending Tube 62slantsix General Rodding Tech 19 06-03-2010 03:04 PM
pickup tube wont fit in pump Johnn Engine 11 04-25-2005 11:12 PM
notching tubing benchracer1 General Rodding Tech 16 04-12-2005 11:02 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-27-2003 11:50 PM
