Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help...can't tighten front wheel
Old 10-07-2007, 07:18 PM
matt167 matt167 is online now
Wiki Edits: 31
spindal must be shot. if it was tightened correctly
tighten nut to 10 ft/lbs, then back off and tighten 10 inch pounds. the tightening to 10 ft/ lbs seats the bearing
Also, don't forget the cotter pin, it will loosen w/o this
