Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help...can't tighten front wheel
Old 10-07-2007, 08:06 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Does that truck have the Dana 44 or the 10 bolt up front? I'm not sure what year they switched. I you have the Dana 44 there is a lockwasher that sandwiches between the inner and outer nuts. The first nut has two pins on it that should be facing out and the lockwasher has several holes and a locking tang on it. The tang should be able to fit in the locking groove on the spindle with two holes in the washer lining up with the pins on the inner nut. Is the lockwasher installed? Is the locking tang in good shape or did it get sheared off? Are the locking pins on the inner nut facing the right way and are they in good condition?
