Help With Carbs - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2011, 07:30 PM
MXrider13's Avatar
The Dude
Help With Carbs
Hey can you guys help me with Carbs, I am looking for a Carb for my 350 and I am most likely going with an Edelbrock 750CFM (there performer series carb). I just learned that CFM is Cubic Feet Per Minute but what exactly does this mean, how much cubic feet is following per minute? Also can some give me what Horsepower ratings I should use with what CFM (I chose 750 from my other thread someone suggested that).
(I am planning around 450 hp to 500 Hp)
Old 07-11-2011, 01:43 PM
fast68's Avatar
likes chevy trucks & boobies
750 is the maximum rated flow
cubic feet per minute yes
Q jets are 800 and 850 cfm
edelbrocks you can get in many sizes, holleys and others too
preferably you will want vacuum secondaries for a street driven vehicle,
you will want to properly jet and set up the carb for the engine it is going on
the parts they put in these carbs are pretty general
it may be too rich or lean for what you need, quite possibly
Old 07-11-2011, 01:50 PM
MXrider13's Avatar
The Dude
Alright I found a vacuum secondary Carb
http://www.jegs.com/i/Holley/510/0-80508S/10002/-1
Hows that one to start?
Old 07-11-2011, 01:58 PM
Last journal entry: Long time no journal entry, pulled hood tonight.
I'd probably go with a 600 cfm carb first. Unless it is really built for it a 600 would be a better bet. There are carb size calculators online, but I don't know how much stock to put in them. The last one I tried said my caddy 472 needed a 635 cfm carb.
Old 07-11-2011, 02:07 PM
MXrider13's Avatar
The Dude
I tired one and I couldn't list horsepower at all, I said I need a 6 hundred and something.
Old 07-11-2011, 02:28 PM
Just re read your first post and that horsepower number is certainly possible, but would probably have to be a very high revving motor. If you were going for that you might even need a bigger carb. If it was a race only motor, or mostly race I think it would be ok. But I don't know if it would be very street friendly. Easiest way to reach your horsepower goals would be with some sort of power adder like turbocharging, supercharging, or nitrous oxide. And those would effect what carb size you choose and how you build the motor. It all works together. For example right now the compression on my caddy is I think 10 or 10.5 to 1. I would have to change heads or pistons to lower the compression if I wanted to run a supercharger. Same if I wanted to run a turbo, and then I would have to run a carb designed/built for a turbo.
Having said all that, if it is a mostly street motor I would probably go with a 600 cfm holley. Or a quadrajet.
Old 07-11-2011, 02:30 PM
MXrider13's Avatar
The Dude
Ill look at the 600 CFM carb
Old 07-11-2011, 06:33 PM
There are no factory stock 850 cfm Q-Jets! Only 750, 800 cfm.
CARBS How big ??? mrobby440 Engine 6 01-11-2007 02:01 PM
409 carbs tucker1 Engine 1 05-27-2006 09:56 PM
carbs 82c10 Engine 1 07-05-2005 10:36 PM
Holley Carbs VS. Edelbrock Carbs. KeithB123 Engine 3 01-12-2004 10:42 PM
