Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - !!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!!
Old 03-17-2007, 04:00 PM
islandman islandman is offline
Hey guy's....
The Carburetor is fixed!!!!
It was some debris, lodged not in the needle valve area but in one of the other small passages!!! I blasted the entire Carb. and tried that gasket seal method and everything worked out perfectly!!!!
My only problem now is the fuel tank...
Does anyone know, "how to clean out (Flush/Seal) a fuel tank while it's still attached to the vehicle"????
