HELP! Carrier shim question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2005, 10:30 PM
I dun learned sumthin
Well Im doing my first rear end gear swap and all seem to be going good so far. My question is what is the best way to get the carrier shim in there. I had to tap on the carrier about a million times to get it to sit in there. is there a better way to squeeze everything in?
Old 02-19-2005, 11:12 PM
Without a housing spreader, NO.
Try rolling the carrier and shims into the housing at the same time. Takes some coordination, and effort, but you can do it. The big problem comes in when you tap on the shim too often and it cracks. Many gear warehouses have adjustable shim packs amd eout of machine steel. Much better gig.
Do not **** the carrier. Life will get worse.
Good luck
Rookie question : gears and carrier 85Sierra Transmission - Rearend 6 11-29-2004 06:47 AM
12 bolt Chevy truck carrier question Gametech Transmission - Rearend 9 02-14-2004 07:04 AM
Hotrodders Guidelines -- READ ME Jon Suspension - Brakes - Steering 0 06-14-2003 05:03 PM
Hotrodders Guidelines -- READ ME Jon Electrical 0 06-14-2003 05:01 PM
Hotrodders Guidelines -- READ ME Jon Body - Exterior 0 06-14-2003 05:00 PM
