Help changing oil pump 74 nova
Hey, i'm going to change the oil pump out on my '74 nova but am having issues getting the pan off. Is there some trick to it? I was thinking about lifting the engine up a bit to clear the crossmember?
Without lifting the engine, you wont get it to clear the crank throws. Myself, I would pull the engine to make it easier to verify pump pick-up to pan clearance...pretty critical.
low to no pressure at idle. its just one of the potential causes. but i'm also putting in a high volume.
ya i know its only a crutch. just like using a heavier weight oil right? but i only need it to last a few more months. i already have another engine for it just need to swap them out.
also, this only started happening after my last oil change where i switched to full synthetic oil that was a lighter weight. |
P.S. I got that B***h out!! I like my other chevy's oil pan much better...
| 1970 nova changing 8.2 to 8.5 soon | gearjammer38 | Transmission - Rearend | 19 | 02-27-2011 04:59 PM |
| Question on changing out holley accelerator pump cams | eric32 | Engine | 1 | 10-02-2009 07:42 PM |
| changing fuel pump on 93 z28 | white trash hotrod | Hotrodding Basics | 3 | 05-27-2009 05:43 AM |
| Changing cam with motor still in car - 72 nova | Warrant | Engine | 5 | 04-24-2007 10:32 PM |
| Changing gears turns nova clone into a dog - engine change effect on converter? | elukas | Transmission - Rearend | 0 | 07-30-2005 07:44 AM |
