Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ? help with Chevy 350 build ?
Old 10-09-2008, 06:24 AM
TroyBoy's Avatar
TroyBoy TroyBoy is offline
Psychomotors
If it were me,I would just get some TRW forged ft pistons(2256F)just for leaning on it alittle harder They are a good piston and not expensive at all. I then maybe would get a Comp cams 280 or Edelbrock rpm cam-had good luck with both.ARP rod bolts and main studs.This will make for a stout bottom end as long as you not doing over 6000-6500 rpm very often or throwing more than a small Nitrous shot at it.If you are just building a good sounding and running street car,This would do nicely and fairly cheap. Just my 2 cents.
