Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with chevy roller cams, blocks....
Old 04-21-2011, 05:45 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by gofastz
thanx guys ill let my buddy know what iv learned, fixin to wast money ant the way to go..........found a vortec block but new ?'s it has a crank sensor on the front, what do you do about that sensor?????
Put it on the shelf in case someone needs one in the future. Use a double roller chain like Cloyes or equivalent. You may have to do a little grinding on the face of the block behind the cam sprocket for clearance. Then use a conventional stamped steel timing cover using all available bolt holes.
