help choosing disc brake kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2010, 03:45 PM
im looking to purchase a disc brake kit should i go with wilwood dual piston non power kit? or with a right stuff detailing power kit? there for the front while the rear remains drums
Old 12-21-2010, 08:35 AM
Last journal entry: 50 Ply wagon
I would go with the Wilwood. You didn't say whether you already have power brakes. If you do then you must go with a power disc brake on the front. You also have to use a proportioning valve to get the right proportions from front to back. A 2lb residual vale should be used inline to the system as well.
1965 GMC 1/2T Disc Brake kit ericehsbrown Suspension - Brakes - Steering 1 02-23-2009 05:20 PM
9" disc brake conversion kit ? 56f100 Suspension - Brakes - Steering 2 06-23-2008 08:57 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Mus II Disc brake kit question Darkman270 Suspension - Brakes - Steering 1 02-18-2004 07:46 AM
