help choosing rear end gears. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2013, 03:43 PM
Slammedsi's Avatar
Truck is a 1977 c10 with a factory 10 bolt and 2:73's. Ive installed a 700r4 with a 2500 rpm stall. I eeally do t know where to start. I have thought about going with 3:73's but been told its way to low while using a 700r trans. The truck is not a daily nore will it hit the highway but it will be driven around town a few times a month. Can anyone recomend a set of gears for me. Thanks.
Old 02-08-2013, 04:31 PM
big gear head's Avatar
High Performance Rear Ends
Most trucks run taller tires than cars, so I would probably go with the 3.73. The overdrive transmission will work well with that.
The '77 should have a truck 12 bolt, not the 10 bolt. If you have the 10 bolt then it must have been swapped at some time.
Old 02-08-2013, 04:42 PM
Slammedsi's Avatar
Never knew that! Learn something new everyday I guess. The rear tires im running are 295/50/15 DR's. The only real plans for the truck is car shows and stop light to stop light "per say". Any other opinions to be had?
Old 02-08-2013, 04:47 PM
Calculators
Play with this some and see what you come up with.
The Following User Says Thank You to big gear head For This Useful Post:
Slammedsi (02-08-2013)
Old 02-08-2013, 05:16 PM
Slammedsi's Avatar
Calculators
Thanks for the link, big head!
Old 02-08-2013, 05:35 PM
Slammedsi's Avatar
Old 02-08-2013, 06:56 PM
fastnloud's Avatar
I have 3:73 gears in my 82 C10, with a TH350 trans, 3000 stall and 275/60/15 tires. It works well for me. Your cruising RPM's, I think will be lower than mine since you have an overdrive trans.
The Following User Says Thank You to fastnloud For This Useful Post:
Old 02-08-2013, 07:46 PM
Slammedsi's Avatar
Thanks fastnloud.
Choosing a rear end for a swap ... TECH Deuce General Rodding Tech 1 07-02-2011 03:33 PM
choosing the proper rear end? weaz4200 Transmission - Rearend 10 10-31-2008 06:21 AM
rear end gears tom1392 Transmission - Rearend 3 08-14-2006 10:36 PM
rear end gears spankthru Transmission - Rearend 2 05-31-2003 06:04 PM
new gears for 3.73 rear end mikereisch Transmission - Rearend 1 11-09-2002 10:13 AM
