Help Choosing a Roller Block SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2012, 01:18 AM
GUITAR1989's Avatar
Guitars & Cars >8D
Hey guys Im putting together a nice little 350 for my truck and Im wondering what roller block would be the best to use for my application. I just dont know the differences between the 86-95 roller blocks and the 96-00 vortec rollers. Im going to be getting some RHS Pro Torkers and using my edelbrock 2101 intake and 1406 carb Im also wanting to transfer over any parts that i possibly can to save money. Will my accessories swap to the newer blocks? Alternator and bracket, GM HEI Distributor, balancer and pully, stearing fluid resivor, mech fuel pump, headers, valve covers and oil pan, timing cover? How much of these parts will I need to replace. If anybody has done one of these swaps and knows what all is interchangable id really appreciate youre input. Also is either block better than the other?
Thanks for your time guys
Shayne
Old 05-22-2012, 05:05 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here is info on the casting numbers to look for.
AFAIK, other than some blocks are 2- and some are 4-bolt and some have and some do not have finished mechanical fuel pump bosses, they're basically the same.
There are some blocks that have the bosses for the spider but the bosses aren't drilled and tapped because the engines were used w/a flat tappet cam. The holes can be easily drilled and tapped using the spider as a template.
Checking the p-rod length can tell you what type of cam is in an engine if the engine is still assembled: ~7.2" = OE hydraulic roller; ~7.8" = flat tappet.
Old 05-22-2012, 07:12 AM
Banned
The cam retainer can vary too, but nbd. Id search for a 4 bolt 880 block, typically they have very little wear as engine management was pretty good by then. You may be able to reuse the entire short block, or just swap rings and bearings after a quick hone.
Switching from FT SBC to roller block? Smackmatic Engine 3 02-21-2010 08:52 PM
SBC Factory roller lifter retro on non roller block 383ram Engine 1 01-24-2009 08:16 PM
Help Choosing Roller Camshaft For 454 Street Car leejoy Engine 1 11-28-2007 10:07 PM
SBC Roller block 47 Coupe Engine 4 04-22-2006 12:18 AM
SBC 5.7 Factory Roller Block with Mechanical Fuel Pump? acr Engine 9 11-20-2004 09:05 PM
