Help choosing Transmision and Converter - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-20-2013, 10:36 PM
vinniekq2's Avatar
read what I said about redline of engine.not peak torque of engine.You dont want to run out of RPM before converter is as close to locked as you can get. Race converters are more expensive than street converters too. The 3500 would work,its just not a race converter.
you are getting close and I look forward to you posting a video of test and tune
  #17 (permalink)
Old 02-20-2013, 10:40 PM
Banned
2nd gens are pigs,, you might (if your lucky and have alot of fiberglass) be at 3200 now..
they stock are normally 3700-4100+ lb curb weight..
  #18 (permalink)
Old 02-20-2013, 11:49 PM
vinniekq2's Avatar
weight
my 1980 Z weighed 3915,very heavy.Thats what the track scale at Mission raceway said
  #19 (permalink)
Old 02-21-2013, 12:27 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
2nd gens are pigs
1970 Camaro
Base Engine curb Weight 6 cylinder 3058, V8 3172
77 Camaro V8 3600
  #20 (permalink)
Old 02-21-2013, 12:31 AM
Banned
Originally Posted by painted jester View Post
2nd gens are pigs
1970 Camaro
77 Camaro V8 3600
ya, base 6cyl no ac no nothing
add console 40lb
add v8 add p/s
add p/b
add a/c add tilt etc etc most are 3800 +
  #21 (permalink)
Old 02-21-2013, 01:15 AM
add console 40lb
add v8 add p/s
add p/b
Im stating they weren't pigs!
I'd like to see a 40 Lb. console
In the 70s optional class rules were you couldn't run a car older then 3 yrs so we bought base line no option cars every 3 yrs. not even radios and put the drive trains and engines in from our older race cars!
Anyway your statment "2nd gens are pigs" you didn't state with all options or if they were 6s or 8s and you rolled all 2nd generation into one big bag
The consoles are 10LBS for a stick 14 auto
RPO Description Weight Factor
C08 Exterior vinyl roof +8
C60 Air Conditioning +112
D55 Floor Console (+10 /w 4speed, +14 w/Automatic)
J50 Power Brakes +10
N40 Power Steering +29
U63 Radio AM Pushbutton +8
U69 Radio AM/FM Pushbutton +8
Z87 Deluxe Interior +28
Z22 Rally Sport Package +27
These are the only additions to delivered curb weight about 200 lbs ad that to base v8 weight of 3172 including full gas tank and all fluids it still only comes to around 3400 # ,
350 V8 engine +56 (+68 w/automatic)Available as "Z28" equipment only - includes additional body and chassis equipment.
But subtract the 27 from above rally pac and its +41
Jester
  #22 (permalink)
Old 02-21-2013, 07:12 AM
Banned
J50 Power Brakes +10 g.m. boosteers are 15 lb + related junk just put my 71 booster on the scale)
N40 Power Steering +29 the power box/lines/pump + fluid is more than 29 lbs maybe 29 dry
inpact laws added tons of weight between your 70's b/s numbers and the real cars weight, nevermind the extra's like frame connectors, caltracts(spabber bars) later cars interior lighting/etc) I've raced 3 2nd gens I know what they lb at.. at dragways with legal scales.. those are the #'s that count
Jester
my 1980 firebird.. was 3900 lb's stock
after removing the console/ carpet/side crash door reinforcements/rear seat/mini spare/jack/ a/c/radio/ ligher than stock wheels (centerline convo pros)/ 400/th350/ ten bolt/
new england dragway and the local metal scale said 3378 lb
the 77 camaro isn't any lighter
to get to 3200 I had to remover factory tank and add a 5gal cell. remove inner bumper supports front/rear...
to get to 3045 lb the door glass and rear window left the building..
real world is different than paper #'s
then add 250-300 lb for cage as you now are fast enough to require it and more.. chromemoly will be a tad less, but today they require more bars so it be a wash
  #23 (permalink)
Old 02-21-2013, 10:04 AM
vinniekq2's Avatar
Looks like we scared the O P away?Thats not good!
Just to clarify,when I weighed my 1980Z I drove it across the scale and it had a 454 in it with all the factory equipment working.Up here in Canada,especially back in the 70s,almost every car got dealer installed under coating.It was a thick tar.Most racers,especially the super stock and stock guys,spent many hours removing the crap. Another thing not often mentioned,repainted cars that just get a scratch and blast,usuallt gain 40 pounds plus or minus.
  #24 (permalink)
Old 02-21-2013, 10:18 AM
rick 427's Avatar
Last journal entry: 33 WILLYS
Vinnie...ya have to admit that this initial thread did kinda shift gears at about half track.
need help choosing torque converter yragat Transmission - Rearend 30 09-16-2008 05:35 PM
Sizing & Choosing a Stall Converter S10 Racer Transmission - Rearend 3 03-18-2008 10:09 PM
Choosing a Stall Converter 35WINDOW Transmission - Rearend 1 04-02-2007 10:28 AM
Choosing the correct stall converter. cujoe822 Transmission - Rearend 3 09-08-2006 05:56 PM
choosing the right converter adam15425 Engine 2 10-04-2004 09:08 PM
