[Help] Clear Coat spraying operation - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2011, 05:54 AM
Hi,
I need to clear coat my car. In the product manual (http://mipa-usa.com/uploads/2K-HS-KlarlackCS85.pdf), it's written:
-Spraying operation : 1 - 2
does that mean that:
1- spray 1 coat, wait to flash (5 min), then follow by 2 coats (with or without flashing?? )
2- spray 1 coat of 2 passes (with or without flashing?? )
i'm really confused and need some help please.
Thanks
Old 07-27-2011, 06:03 AM
deadbodyman's Avatar
Wiki Edits: 11
Nothing to it .Spray the first coat just like you want it to look ,let it sit 15-20 min,do the same with the second coat ,walk away, come back in the morning and untape it...
Old 07-27-2011, 07:14 AM
Thanks
Thank you deadbodyman
spraying clear coat on top of clear coat? bennecc Body - Exterior 9 05-08-2012 05:59 AM
debris coming out while spraying clear coat jfaur Body - Exterior 8 07-04-2011 08:12 PM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 11:56 AM
Acrylic Enamel vs. Base Coat Clear Coat 70chevy Body - Exterior 175 11-11-2009 03:07 PM
Base coat clear coat repair problem TimeBandit Body - Exterior 2 09-03-2008 07:22 PM
