Help with Cloyes 2 piece timing cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2011, 08:29 PM
Landshark928's Avatar
FrankenPorsche
I had cam walk on my solid roller cam SBC. I had an aluminum button and a decent cloyes one piece cover.
I figured I'd try a two piece adjustable Cloyes unit instead. I am trying to finish installing it now and running into issues. The main piece is on. I have the adjustable button all the way out, away from the cam and towards the cover.
Normally once the 2nd piece is installed, you screw in the button until contact and then back out 1/3rd turn and lock her down.
My issue is once I tighten down the 2nd piece, the button is tight and will not screw in at all. Zero lash. The cover is not bowing out that I can tell.
Cam is a Lunati VooDoo 60133 if that matters. Will a zero lash condition hurt since it's a roller button? I'm guessing yes. Should I double up the timing cover gaskets to see if that helps? Or cut a round gasket for the 3nd piece to make some space? Or should I try filing down the button a tad?
Thanks!
Old 10-14-2011, 11:05 AM
RippinRon's Avatar
I have the same cover on my solid roller 350 too. My instructions said install at zero lash and when the engine is warm you get clearance.
Old 10-14-2011, 10:42 PM
FrankenPorsche
Thanks, I re-read the instructions and they state to crank it in to zero lash and then back out 1/3rd turn. No mention of temperature, although it would make sense to account for it and adjust when warm.
I ended up taking the roller button off and grinding down the adaptor plate. Then re-installed the button. Did that a few times until I had taken off enough to make adjustments. I have it at 1/3 turn out cold right now. I should have her back together tomorrow morning. I'll double check lash when warm. There is just enough room behind the water pump to get a 90* screwdriver in.
Just seemed odd that cam lengths could be so different as to need grinding.
It's been a real PITA project. Not being a SBC guy, I didn't realize you had to lower the oil pan to change the cover. Even though I put the darn thing together... Old cover popped right out. To get the new one in, I had to take out the front mounts and raise the engine to loosen the pan enough. Since it's a transplant engine I only have about 1/8" between the bottom of the custom oil pan and my lower cross brace.
Old 10-15-2011, 02:42 PM
RippinRon's Avatar
I just dug out my instructions and looked them up on cloyes website and it says.
"The camshaft endplay is now set to “Zero” lash. Due to the higher thermal
expansion rate of the aluminum timing cover compared to the steel cam button assembly, there will be a small amount of endplay with the engine warmed up.|
Old 10-16-2011, 10:18 PM
FrankenPorsche
Odd my instructions in the box do not match the online instructions. I'm going to try the zero lash setting tomorrow. Luckily I can reach the adjustment under the electric water pump with out taking anything off.
Cloyes two pc timing chain cover? Bowtie man Hotrodding Basics 0 08-27-2011 10:04 PM
Found problem with cloyes timing cover. eric32 Engine 3 07-23-2009 07:21 PM
Timing cover 2 piece strangedays Engine 3 04-16-2009 05:22 PM
Mr. Gasket two piece timing cover nabx22 Engine 15 12-13-2004 06:39 PM
Two piece timing cover= 2x leak problems? killerformula Engine 11 11-26-2003 06:57 AM
