Help converting tire/wheel size for tranny build - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2005, 06:37 PM
57NAPCO's Avatar
She got the Rod, I got the sha
Im needing some conversion help with my present tire/wheel combo. Im having a custom 700R4 built for my ride. The gentleman building it wants to know what the total height from ground to top of tire would be in inches if they were 15 inch rims and tires
my tires and rims: MBF Goodrich 235/50 ZR18 M+S on 18 inch rims
I've e-mailed a couple of tire stores and they dont seem to be interested in helping a person out..
Thanks Guys..
Old 02-19-2005, 11:19 PM
There's a tire diameter calculator at http://tciauto.com/tech_info/speedo_gears.htm
Old 02-20-2005, 04:47 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
My son builds transmissions and I'm wondering why this guy wants this information. I would think rollout would be more than enough.
Old 02-20-2005, 10:02 AM
57NAPCO's Avatar
JimFulco/BillyShope
Thanks for the link to the conversion tables,
Yes he asked me also to get the rear-end ratio, which i understand , and my assumption on the tire conversion to inches/Ht. would be for the speedo gearing combined with the rearend ratio, just a guess on my part of course...
Hes putting in heavier clusters and building the same trans as Raptor makes for about half the money
I,ll see if i can figger out the conversion from the site u gave me Jim...
thanks guys
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
