Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with crossmember on th300&th400
Old 12-28-2002, 10:13 AM
josh7681 josh7681 is offline
New Member
I have a 69' camaro that had a TH350 in it and I went with a TH400. It is true that a manual and TH350 will use the same crossmember, but the TH 400 will not fit. I had to order a TH400 crossmember (I got it from "THE PADDOCK"). I had to do a little "coaxing" with the subframe holes to line them up with the new crossmember, but it fit great. The only thing that really got in the way, was the pipes. I run a set of Headman full length headers that were bent for the TH350 so it took some more coaxing with the pieps to fit. Been running the TH400 for about 2 years now, and no problems.
