Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with crossmember on th300&th400
Old 12-28-2002, 09:43 PM
burnout burnout is offline
[quote]Originally posted by burnout:
[QB][/QB]<hr></blockquote>I agree with those above, but I have done this swap lots of times by simply making 2 extensions of 3/8 steel around 6 in long x2in or so wide drilling them out in 4 places so that they will bolt up to the rear most holes in the sub frame cross member mount area, and bolt the cross member to the remaining holes of the adapter,before drilling,you need to clamp this stuf in place and mark the points to be drilled! worked for me lotsa times and no welding needed... this is not to say that the other ways sugested above aren't xlent, but just a quick trick that worked well for me. best o luck with whatever way ya go!
