Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help deciding on headers for my 350
Old 08-28-2012, 09:57 AM
1972 El Camino's Avatar
1972 El Camino 1972 El Camino is offline
Originally Posted by cdminter59 View Post
Well it looks like you have two choices either use the hedman headers or do away with the smog equipment. Is this a show car that you want to keep factory correct? If not take all the smog equipment off and buy the Hooker headers. They are made better. Heavier gauge metal tubes and flanges are probably thicker too. If you have a factory numbers matching car that you take to car shows keep it as it is.
its not a numbers matching car. your suggestion makes sense.
was trying to find a post that read something about the way the air pump functions that it actually helps the car to run better because it aids in the burning of excess fuel as well as aiding in keeping things cooler but cant seem to find it now.
i wondered if someone would come along and post advantages to having the system in place since after all it isn't the system itself that weighs on performance but how the cars were tuned at the factory that these system came stock on.
