Help with dent repair - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-30-2013, 09:10 AM
Hey guys,
First of all, Thank you all for helping, your instructions really helped and was quite accurate.
So I found some free time and someone to help me.
I started hitting as instructed while someone is supporting the other side.
At first it looked like it had no effect, then I tried a heavier hammer, because the access to this place is limited the hitting was done from 10-15cm distance so the smaller hammer didn't do much good.
After I switched hammers things started to move, slowly I found the right spots to hit and it started to get out.
In my opinion its not perfect, and the center dent is still a little inside but I think its at a level where it can be covered with bondo.
I'll let you be the judge, I attached images.
I assume there are some little high spots left that needs to be tapped, but I didn't have sand paper to test.
ID:	75301   Click image for larger version
ID:	75302   Click image for larger version
  #17 (permalink)
Old 06-30-2013, 10:20 AM
It looks like you are well on your way. In that first picture it almost looks like there is a brow way above the body line! Be careful, as it may be. Feel that door above the body line, feel it vertically, slide your hand up and down on that area while standing next to it, do you feel anything? That dent was pretty profound and with the intrusion beam right above it holding the metal as the dent was created it is a very real possibility that the skin buckled above the body line.
  #18 (permalink)
Old 06-30-2013, 12:06 PM
Thanks Brian.
You'll have to forgive me, my English is pretty good but I'm not familiar with all the technical terms.
Are you referring to the area above the red line in the attached picture?
Intrusion beam being the red line?
Thanks.
  #19 (permalink)
Old 06-30-2013, 12:17 PM
Yes in the first picture on your last post it looks like there is a brow or "buckle" in the panel running horizontal above that line a few inches. I may be wrong it could simply be a reflection but it looks like a brow.
Roof dent repair--1967 Mustang Lizer Body - Exterior 23 03-19-2011 07:05 PM
Roof Dent, How Much to Repair? Ayh127 Body - Exterior 6 03-04-2010 01:06 PM
Dent Repair esahlin Body - Exterior 4 07-02-2007 08:59 PM
Is this dent a good beginner repair? schnitz Body - Exterior 9 06-07-2006 06:25 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 10:00 PM
