YES I FEEL A RIDGE WITH MY FINGERNAIL. I AM CONCERNED THAT IT WILL DESTROY THE CAM AND GEAR AGAIN! WHEN I PULLED THE DISTRIBUTOR OUT (REPLACING MY HEADS) THERE SEEMED TO BE PLENTY OF OIL ON THE DIST. SO I DON'T THINK IT MIGHT BE A LACK OF LUBRICATION. IS THERE ANYWAY OF INCREASING OIL FLOW IN THIS AREA? THE WEAR MARKS ARE TOWARDS THE BOTTOM HALF OF THE GEAR (NOT RUNNING OFF THE BOTTOM) I JUST GOT SOME INFO FROM CRANE CAMS:
Distributor gear wear.
The main cause for distributor gear wear is the use of high volume or high-pressure oil pumps. We don’t recommend the use of these types of oil pumps. If you do run these types of oil pumps, you can expect short life of the cam and distributor gears, especially for low speed running, in street type applications. If you must run these types of oil pumps, you can increase the life of the gears by adding more oil flow over the gear area to help cool off the point of contact.
HOW DO I INCREASE THE OIL FLOW???
ANY IDEAS?? <img src="graemlins/pain.gif" border="0" alt="[pain]" />
[ January 03, 2003: Message edited by: Knobie ]</p>
