Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with Driveline Angles on my Hot Rod - Pictures inside...
Old 12-01-2012, 07:56 AM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
When I set all mine up.. I put the carb base level, That will have the trans down 3*, Then I set the pinion 3* up..
Now if it's for the track, I will set the pinion level.. When setting it up this way, Sometimes it will look funny and you will think something isn't right,, But it work's.. Good luck..
And as far as the side to side.. Some cars came with the drive shaft off center..
