Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with Driveline Angles on my Hot Rod - Pictures inside...
Old 12-01-2012, 03:57 PM
123pugsy's Avatar
123pugsy 123pugsy is online now
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by mason71 View Post
Hello,
Working on my rear suspension I realized the pinion on my rear-end housing is offset by 2.75". This throws my drive shaft angles out much further than I was hoping.
I plan to run a 3.5" aluminum drive shaft.
As photoed the engine and transmission are pointed down in the back at 3* (carburetor base level) and the pinion is pointed down 1*. With the tape measure stretched across the span it reads 8*.
Are these angles too high even with such a short drive shaft?
Should I bring up the engine and transmission (carburetor base off level)?
Am I going to need to source a equal distance rear-end?
Thanks for any help!
First thing you need to do is get the pinion up to 3*. The angles need to be the same.
That 8* you have with the pinion down 1* will be more when the angles are the same. (pinion up).
If it stayed at 8* less 3* is 5* angle. They recommend 3* to be optimal but 5* may be OK.
But, with your pinion down 1* and rotating it up to 3*, the angle will end up more than 5*.
The suggestion about lifting the tranny up seems like the best way to go.
