Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with Driveline Angles on my Hot Rod - Pictures inside...
Old 12-01-2012, 04:16 PM
cliff tate cliff tate is offline
drive line angle
read the dana artical. it claims aslong as both face angles ar within 5dg tpparalel you ar ok.you do not toline up the output of the engine eith the diff,you need the out put face to be with in 5dg max of input of diff.the diff input can be3or 4 in left or right of engine.the alighn ment should be measured withwheels on the ground weight. look at the older ford vans,the diff input is way over to 1 side,also look at 4x4s that ar lifted,they ar a bit to radical. you can get a magnetic degree gauge for unde20.00 that is all you need. the engine center line must be paralel with the diff. but up down sidways ok if face angles within the 5dg
