Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with Driveline Angles on my Hot Rod - Pictures inside...
  #23 (permalink)
Old 12-04-2012, 10:48 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
[QUOTE=mason71;1619133]
[U]Denny: With short driveshafts it is very important to have everything inline and no offset at all.
You will need to install a rear end that has the pinion in exactly the right place to allow for a straight line from pinion to trans.
Thats what I was talking about.. Your diff is "above" the center line. With a short shaft you could be setting yourself up for shakes.
I get rods in that have a offset side to side since the 8.8 is so popular and most of them are fine.
It's the up and down I worry about.
