Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with Driveline Angles on my Hot Rod - Pictures inside...
  #30 (permalink)
Old 12-05-2012, 10:54 AM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Originally Posted by prostreet6t9 View Post
Very true.. Except the diff will always tilt up under power. How much will depend on the suspension.
Don't be leaving all mad Randy
Well.. I hope you understand that will only happen on a leaf spring set up.. 4 BAR ,Ladder bar, And for link,, the rear end doesn't change.. Only The angle of the drive shaft will a little..
And I'm not mad... I feel if he believe's denny,, Go with it..
