Help with Driveline Angles on my Hot Rod - Pictures inside... - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 12-05-2012, 11:02 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
Originally Posted by mason71 View Post
I am running a four link.
You have adjustment on the bars to change the pinion angle IF you have any problems.. (I don't see where you would).. Low ride trucks go down the hwy dropped as low as they can run with the rear end higher then the trans everyday with no problems other then dragging the ground...
If it was Mine I would set the carbs level, Set the rear end 3* up to match the 3* down and move on... You start lifting the trans then the motor look's like it is taking a nose dive... If you want to lift the trans.. Lift the motor as well, (Keep the carb level)..Here's a shot of the truck we built for my son... You can't see the true angle of the drive shaft.. But when its aired down the rear end is as high as your's..And he can run all day long like that..
  #32 (permalink)
Old 12-05-2012, 11:04 AM
1971BB427's Avatar
Perfect! Then get it close, and you can do any adjustment after a test drive, if needed.
  #33 (permalink)
Old 12-05-2012, 11:07 AM
From the angle we are looking at your angle finder,, If we seen it from the side it look's to be 5*.. Is that right ??? We are seeing it from a angle,, Not dead on..
  #34 (permalink)
Old 12-05-2012, 12:29 PM
mason71's Avatar
Last journal entry: mock up
Its closer to 8*, it was kinda hard to take the picture and hold the angle finder
Driveline Angles on V-8 Vega Hoonbash Transmission - Rearend 2 10-10-2008 05:39 PM
Old question....new problem....driveline angles? Stovebolter Transmission - Rearend 5 08-27-2008 03:42 PM
Pictures 2007 NHRA Hot Rod Reunion National Trail Ohio 1930u Hot Rod Art 16 07-16-2007 09:10 AM
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 32 05-11-2007 07:22 PM
Hot Rod Reunion Pictures 2006 ? street rodder 1937 Hotrodders' Lounge 1 06-21-2006 05:45 PM
