Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help!!! Drum Brakes!
Old 10-03-2006, 10:33 AM
Pepsi Pepsi is offline
They are probably rusted there solid... take a big hammer and give her all she's got till it comes loose again... if they come loose and still cant pull them out... your drum is probably worn and there is a edge on the friction surface inside your drum that keeps you from pulling her out. Now you have to loosen the brake pads inside the drum by maybe bleeding the brake or there may be a rubber plug behind the back plate of your drum where you can reach a adjuster screw. loosen it and you may be able to pull the drum out .
