drum brakes!!!!
Ok, I found the problem to why I can't remove the drum. The drum turns freely and it moves in and out about a 1/2 inch. The reason it only moves a 1/2 of an inch in and out, is because this damn front piece that the wheel studs go through is keeping the drum from coming off. It almost seems impossible to replace brake shoes on a 3/4 ton pickup. How to you get the drum off, if this circle wheel stud thing is keeping it from coming off? How do you get brake drums off of a 3/4 ton?!!!???!!!!
thanks in advance,
Mark
