Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help!!! Drum Brakes!
Old 10-04-2006, 05:00 PM
61bone 61bone is offline
Last journal entry: frame build
sounds to me like your floating axle is whipping your axle. Take the ring of bolts out of the end of the axle and remove axle. Inside the hole there are two large spanner nuts and a retainer on the spindle. Remove these and slide the drum and carrier assembly off the spindle. Don't drop the outer bearing in the dirt.
