Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help!!! Drum Brakes!
Old 10-05-2006, 08:10 AM
markzepp820's Avatar
markzepp820 markzepp820 is offline
re: Help!!! Drum Brakes!
KULTULZ, The peice I'm referring to is on the outside of the hub itself. The wheel studs come out of the drum, then through this guide(circle piece). The stud guide peice is keeping my drum from coming off. If this piece was off, then I could easly slide the drum off the hub.
