Help!!! Drum Brakes! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-05-2006, 08:13 AM
markzepp820's Avatar
re: Help!!! Drum Brakes!
By the way to everyone. This is a SINGLE wheel truck.
  #17 (permalink)
Old 10-05-2006, 08:23 AM
  #18 (permalink)
Old 10-05-2006, 08:25 AM
I got this photo from the internet, but is the same as mine. The piece that the wheel studs go through in front of the drum, is stopping me from getting the drum off.
  #19 (permalink)
Old 10-05-2006, 10:30 AM
aka Duke of URL
The Photo Shows Everything
OK. You have an Inboard Drum Design. This is unique and the axle has to come out first. On the Outboard Design, the drum will slide over the hub.
Do me a favor when you get it apart. Can you give me the exact brake shoe size (inside drum dia. and width of shoe pad) and the Rear End Asm. Tag Info (if still there)?
  #20 (permalink)
Old 10-05-2006, 03:45 PM
I got the drum off!!!
I finally got the drum off. I took the axle shaft out, then removed the nut off the hub that requires a special tool. Didn't have that special tool, so I used a screw driver and hammer. Then I removed the locknut, then inner nut, and then she slid right off! Piece of cake, I just wish my manual would have told me this in the brake section. But I have to say, it was very inconvient to remove part of the drivetrain just to get to the brakes. This has got to be one of the things I hate about full-floaters. Anywase, thank you all very much for your input. MISSION ACCOMPLISHED!
  #21 (permalink)
Old 10-05-2006, 03:50 PM
Oh Yeah
KULTULZ,
I already put it back together, sorry. But I did measure the pads to determine 13 inch brakes or 11? inch brakes. The shoes width is 2.5 inches. Basically, alls I know is, this is a 14 bolt full-floating axle with 13 inch brakes, 10.5 ring gear, and 3.73 gears. I love it, very strong and perfect gear ratio for me. Great torque and decent highway rpm's.
Last edited by markzepp820; 10-05-2006 at 03:55 PM. Reason: forgot to had more info.
Help: How-to on Drum Brakes 65Stanger Suspension - Brakes - Steering 3 02-18-2006 06:15 AM
65 Impala Drum Brakes Question EazyDuzIt102 Suspension - Brakes - Steering 2 08-09-2005 04:16 PM
Drum Brakes Spring question JamesRS Suspension - Brakes - Steering 2 04-12-2005 04:02 PM
Drum brakes smelling bad nitsud08 Suspension - Brakes - Steering 5 04-11-2005 05:15 AM
Drum Brakes WildOne Introduce Yourself 1 12-03-2004 09:41 PM
