Help with dupont chroma base - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2006, 02:04 PM
Hey guys, Im getting ready to paint my girlfriends 2005 honda accord rear plastic bumper I have used a high build primer and sanded with 400. I purchased some dupont chromabase satin silver and some chroma clear. I have never used this. the guy at the supply store told me I don't need to sand the base before shooting the clear? Is this true? also the directions say to flash basecoat 15-30 minutes before clearing. What is flash? Sorry for all the questions but I don't want to waste any material, cant afford to buy more.
Old 10-19-2006, 02:28 PM
Found was I was looking 4.
Old 10-19-2006, 09:58 PM
colormecrazy's Avatar
Paintshop Dog
Definitely do not sand base before you clear!!
Old 10-20-2006, 04:06 AM
adtkart@aol.com
Also don't watch a clock for the ideal flash time. That "idea" time will vary depending on the color, shop/metal temp, and humidity, and basemaker/reducer that is used. If you clear too soon, you may end up with solvent pop. Been there, done that. I don't remember what the recoat window is, but I usually wait atleast an hour or 2 before clearing, just to make sure. That's time that I can spend doing something else, not trying to get rid of solvent pop.
Aaron
Old 10-20-2006, 09:33 AM
Thanks guys!
Old 10-20-2006, 12:35 PM
There is a 24 hour window to clear and yes the longer you wait to clear the less chance you will have with solvent pop.
Old 10-31-2006, 01:57 PM
Well guys its all finished turned out pretty good only problem I had was with the bc the satin silver has some glitter in it it kind of shot out in bunches in some areas probably because of the gun I used, just some larger patches with glitter other than that Iam happy with the way it turned out. Should I sand the clearcoat? If so how long should I wait? Thanks for all the help fellas. Jeff
Old 10-31-2006, 05:37 PM
That would be called mottling. Silver is one of the tougher colors for it if you are not experienced spraying and have a well set up gun. And I believe that is metallic. Glitter is found in the crafts section If you are happy with the way it looks then no you don't have to do anything to the clearcoat. If you have orange peel, dirt nibs, or other perfections you would like to get out, then wetsanding and buffing will take care of a lot of little imperfections, if you put on enough coats of clear to do so. Do a search on wetsanding and buffing, the subject has been covered very often on here.
Old 10-31-2006, 06:48 PM
Originally Posted by kenseth17
That would be called mottling. Silver is one of the tougher colors for it if you are not experienced spraying and have a well set up gun. And I believe that is metallic. Glitter is found in the crafts section .
Thanks for clearing that up
Dupont base question hemi43 Body - Exterior 1 05-24-2006 09:39 PM
Best DuPont base??? SideSlip Body - Exterior 4 02-17-2006 01:50 PM
PPG D800 vs Dupont Chroma delanda Body - Exterior 0 07-19-2005 04:00 PM
Dupont Clear over metallic base dave220 Body - Exterior 5 04-01-2005 09:16 PM
