Please help !!!!
I had this posted in electrol forum,but no one replied to it , so im trying here,
My son has a 1996 Toyota Tacoma 4x4 ext cab truck engine 2.7 His headlights only work if you pull back on the light control switch ,which is the flash position. I bought another light control switch, and it still does the same thing. all fuses and relays are ok, with the lights turned on ,theres only fire at top terminals on both headlights., theres 3 terminals on the headlight bulb. any advice would be great.
bad wire bad switch or bad connector is the only thing it can be. Does the headlight circut use a relay. Many newer cars do the switch only carrys a 12v source to switch the relay for high low and both which is what you should get if you pull the switch backwards. |
| Electrical problem | johntm | Electrical | 26 | 09-14-2012 07:57 AM |
| Electrical Problem | headturner73 | Engine | 3 | 04-10-2007 09:37 PM |
| electrical problem | dragonboy | Electrical | 1 | 01-22-2007 02:37 PM |
| electrical problem | SmokeGetsInYourEyes | Electrical | 6 | 01-29-2006 03:12 PM |
| electrical problem | hotrod68383 | Electrical | 3 | 12-05-2004 03:50 AM |
