Help with engine bog ??
My son just bought a 1995 z71 4x4 truck with a 350 engine with a 2 barrel Throttle body injection.. The truck runs good . The problem is if you barely press the gas pedel ,its starts to bog down ,and runs rough , but if you just press it , it drives fine . I dont have a way to check the fuel presure, but was wondering if it could be the fuel pump . any help would be great.. thanks..
anybody !!!!!
It's not the fuel pump, you need to see if it's throwing any codes with a scanner. Just a thought, on a 94 you can check for codes with a paper clip, not sure about a 95.
[QUOTE=hpete]It's not the fuel pump, you need to see if it's throwing any codes with a scanner. Just a thought, on a 94 you can check for codes with a paper clip, not sure about a 95.[/Q , I went and got a book on it today, and i believe that the check engine light bulb has been removed or something cause it should be on when it acts up.. thanks for the reply..
Did this just start all at once, what have you done to it so far if anything. The more information you hive the more and better quality responses you will get.
I would look for vacuum leaks and see if the TPS resistance change is smooth when you move the throttle as a start.
Artificial Intelligence is no match for Natural Stupidity Chet |
there was no codes stored , and i checked for vacum leaks and didnt find any. was wondering maybe if it might still be the fuel pump.. any suggestions ? thanks
Throttle body
Its possible that you have a dirt ring inside the throttle body.Buy some B-12 fuel injection spray cleaner..Spray into the Throttle body and rev at the same time.You should be ok after that...
| 350 Crate Engine: Loud humming sound after engine warms up | sofa1515 | Engine | 2 | 01-11-2010 06:48 PM |
| Engine Help. Engine Turns over Hard, like siezed yet runs awsome. | Merle9069 | Engine | 3 | 10-05-2008 06:38 PM |
| I need engine mount bracket ideas 1930 chevy with 302 boss engine. | Riley | Engine | 3 | 07-25-2008 07:29 AM |
| say you have a THOUSAND horsepower engine..... (technical engine question inside) | lowROLLERchevy | Engine | 14 | 02-24-2007 08:26 AM |
| the best engine parts, chain vs. gear, engine combos | jollygiant_57 | Engine | 6 | 05-01-2002 09:34 AM |
