Help - engine cutting out - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2010, 09:23 PM
Was out at the track the other night and after a few runs with no hint of a problem my motor cut out just before the 1/8 mile mark. changed a suspect piece of fuel line and the filter and tried again. Car was great for about 3 or 4 runs then did it again. It didn't kill the engine completely and as it cut off I backed off the gas and it went to an idle, when I gave it some peddle it ran fine at part throttle. and was fine until I tried it again, then same thing at the same point in the track. If I parked it for awhile it was fine again for a couple runs then did it again.
Could it be:
vapour lock- my fuel line runs up the front of the engine and the motor was running on the hot side of 200
not enough fuel/weak pump- original fuel pump with return line
to lean- plugs looked ok, but with the converter it spends more time at high rpm - might be reaching a bit with this one
This was the first time out with a 2800 stall as opposed to the stock converter. Engine is a 454 with edelbrock, xe268, headers.
your thoughts would be appreciated.
Old 08-29-2010, 09:28 PM
my guess is fuel issue, sounds like fuel pump might be heatin up and not pushing right i've had a few fuel pumps actually do this exact thing, once allowed to cool and set they work for a time and cut back out again.
Old 08-30-2010, 10:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
An insulator under the carb can help if the fuel is percolating. Check the fuel pressure AND volume. You want about 5 psi and for a 400 HP engine the pump should be capable of flowing 40 gallons/hour.
If you are using a Q-jet carb, they have a small fuel bowl capacity that makes them more susceptible to run low during a run- if the pump's not up to the task.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 06:55 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 08:26 PM
Downtrack problems- Engine cutting out at rpm racerx308e Electrical 7 08-13-2004 09:53 AM
Engine cutting out at the track! slowformula Engine 7 03-11-2004 02:56 PM
