Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HELP! engine wont idle!
Old 09-25-2012, 12:35 PM
eric32 eric32 is offline
Well there are several things you can check out and first make sure your timing is correct as that will effect carb operation. Also I am no expert on qjets but only on holleys but you might want to check your idle mixture screws to make sure there adjusted correctly. Those are to very important things that can cause what your experiencing.
Eric
