HELP Equal length shorty headers for a sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2012, 04:42 PM
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
So, I've called, hugger, hedman, hooker, sanderson, schoenfield, jegs, and summit.
I can't find equal length shorty headers for a sbc. Does anyone know anyone that makes such a header? If at all possible I am looking for 1 5/8 primaries.
Old 04-18-2012, 05:30 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
Never heard of them
Equal length provides primary tubes 'tuned' to optimal length for a given application, the main benefit is equal back pressure to all cylinders to 'balance' the VE of all cylinders; and tuning to improve scavenging and minimize reversion.
Shorties (also called block huggers) are designed to provide the least overall back pressure while maximizing fit of the headers in the engine bay.
The geometry of shorty header design precludes an equal length of the tubes from port to collector.
In other words if you have a tight fit use the shorties, if you're racing use the equal length headers and move stuff as needed to make them fit. If you're racing and have a tight fit (can't fit the long tubes); in all but a few cases the shorties will be fine.
Hope this helps.
Old 04-18-2012, 06:03 PM
68NovaSS's Avatar
Wiki Edits: 9
Hard to believe, you need to look a little harder, practically all the manufacturers you list make them, and Summit and JEG's carry them all.
Moving to Basics.
Old 04-18-2012, 06:27 PM
I called them... I couldn't get a hold of Kooks today. So no they really don't have equal length block huggers as I am looking for.
Now, equal length long tubes. yeah they do.
the only equal length shorty header that I could find was for 5.0 mustangs bade by bbk.
68novass if you have a link to a set, please post it.
these are the bbk header that I am talking about.
http://www.summitracing.com/search/B.../?autoview=SKU
Old 04-18-2012, 07:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
One reason you can't find them is because once you bolt on exhaust pipes, mufflers and tail pipes, the gains you might have seen from equal length primaries will be mostly lost. This is especially true of shorty headers as they generally lack collectors altogether.
In any event, especially on a street performance engine, there's no benefit and possibly deficits to using equal length headers, be they short or full length. This is because having unequal length primaries tend to widen the powerband, and while the peak may be down on power from a carefully tuned induction/equal length exhaust header system, the average power/power under the curve often favors unequal length primaries.
Old 04-18-2012, 09:44 PM
68NovaSS's Avatar
Wiki Edits: 9
Give Lemons's a call, they made a set for Camaroman7D that wrapped the frame rail on his new Skylark ProStreet car, so they'll do anything you can afford to pay for.
shorty headers huyett4 Engine 2 02-28-2012 05:28 PM
shorty headers wildthing Engine 5 07-12-2008 10:28 PM
Edelbrock Shorty headers or Flowtech Full length??? Houman SS '70 Engine 7 01-08-2008 03:30 PM
What are the typical performance gains for equal length headers over OE Arns85GT Engine 19 02-08-2007 02:12 PM
shorty headers????? fireforsin Engine 2 03-11-2004 08:32 PM
