Help - Family car problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2007, 07:23 AM
Irelands child's Avatar
I need some more brain power at work for me
I put new Hawk ceramic brakes and Brembo rotors on our '03 Escape -
While I had absolutely no problems with the installation and the brakes are very much better then the OEM equipment, the vehicle has been plagued with what I have to describe as a less than great pedal. I have bled them on the off chance that I may have introduced a bit of air in the lines when I retracted the caliper pistons and no air was expelled. To the best of my knowledge there is no external indicator on the proportioning valve and no check brakes dash light has come on. I cannot imagine that the MC is damaged, but stranger things have happened. So with that being said, is there something I have overlooked?
Dave
Irelands child
Old 02-20-2007, 07:48 AM
New brake pads, especially high performance ones, need to "bed in". Braking feel usually improves over the first 500 miles or so. Also, some high perf brake pads are designed to work best when the pads are hot and have noticeably less braking force when the pads are cold.
Old 02-20-2007, 07:58 AM
These pads (and rotors) were bedded in exactly how Hawk and Brembo recommended then "babied" for several more several more similar heat/cool cycles. They have about 2500 miles on them now after a 1400 mile trip this past weekent to VA. and stop beautifully - except for the additional 2-3" of pedal throw. This is at least 2X more than the OEMs - which is why I'm concerned that the MC is having some problems. The pedal is not soft - just way too much free play .
Dave
Irelands child
Old 02-20-2007, 08:24 AM
Chopt 48's Avatar
Are you able to pump up the pedal? When sitting still, If you pump the pedal slowly will it come up a measurable amount? That would indicate air in the system.
I'm not sure if that car has disk or drum on the back. If it has drum are the rear brakes adjusted correctly?
There are usually one of two reasons for a master cylinder being bad. One is leaking. The other is bypassing where it leaks internally and the pedal will slowly drop when holding normal pressure on it. Both are cause for replacement.
One more thing, some systems are inherently difficult to bleed an take special measures. You might check to see if there is preferred method of bleeding your system.
Old 02-21-2007, 07:39 AM
The pedal pumps and then tends to drop a bit which is one of my indicators of a MC that has an internal problem. The rears appear to be adjusted correctly.
Just for yuks, I am going to try bleeding one more time. There should be absolutely no reason for air in the line as the bleeders were never opened prior to my initial bleed a few days after the pad/rotor installation.
Dave
Irelands child
Old 02-22-2007, 01:26 AM
If you have air in the system it's unlikely the pedal will 'pump up'. Generally if you can pump up the brakes then shoes need adjusting. Is it a drum rear application?
I've had aftermarket pads that had thin backing plates which flexed and gave a poor pedal. Some calipers flex so much ( like my 96 Holden Statesman) that they give a poor pedal.
As this has only become a problem since the brake change, I'm guessing one of four causes.
1 - pad flex.
2 - pumping the pedal too hard to seat the piston can cause m/cyl failure ( it does on 72/78 local Falcons and w202/210 M/Benzs) - cracked piston in m/c.
3- Rusty caliper piston (NY salt) has 'rolled' the seal and introduced air.
4 - Rusty caliper slides are causing the caliper to '****' or stick at an angle.
As I said earlier, air won't pump up. So I'm leaning towards 1 or 2.
Ian.
PS. The word that was deleted describes the way some things can sit out of alignment, it is also the name given to a male gamebird or an important part of the male anatomy. If I'd wished to be profane I would have been far more creative.
Last edited by IanRiordan; 02-22-2007 at 01:32 AM. Reason: some words don't come up.
Old 02-22-2007, 05:09 AM
poncho62's Avatar
Wiki Edits: 5
When you pushed the caliper pistons back in, did you loosen the bleeders. Maybe, if you didn't the MC doesn't like that much reverse flow and popped an internal seal........just a guess.
family car wckd_1 Engine 6 10-22-2006 05:52 PM
It's all in the details... Nightfire Hotrodders' Lounge 18 09-16-2006 09:53 PM
Buyer Beware................... poncho62 Hotrodders' Lounge 10 05-19-2005 09:40 PM
Cavalier Starting Problem...help about to light car on fire oldschoolrods Electrical 1 08-05-2004 09:46 PM
i hope i'm posting this right 1992 Lincoln Town Car AODE tranny problem maglinvinn Transmission - Rearend 1 04-25-2003 02:47 PM
