Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help finding piston
Old 04-18-2004, 04:43 AM
arch's Avatar
arch arch is offline
My bike has 4wheel disc brakes
Help finding piston
I've looked all over the internet looking for this piston, I thought maybe somebody here would know where Im not looking.
So far all I've come up with is ethier a one with a 0.0875" piston down bore, domed, or custom made piston. None of which will work.
(Ive looked at, Manley, Ross, JE, KB, speedpro, Mahle, Probe, SRP, Top-Line, TRW, Venoila, and Wiseco so far)
Here's the specs it needs to be:
4.125" bore, 6.000" rod, around 10.5:1 comp. ratio with 64 CC heads and a 3.875" stroke. Pref. Hypereutenic or however its spelt. (1.062-1.078" compression height) (0.9272" floating pin)
JE has the closest P/N 182033, but it has a 3cc dome and a 13+ compression ratio.
Thanks in advance for your help.
