help on finding the right cam....... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2010, 07:41 PM
i have a bone stock, org 72 350 motor that i would like to up grade some what. i need help figuring out the correct cam to use. my car will be a mostly street car very little track time. just a cruiser. would like a good sound a lope to it. so far the 350 motor i said is a stock strong runner, is has a set of alum corvette heads,performer RPM intake and edel 600 carb. headers with full exhaust. some help on locating a cam???? im sure you guys could throw some numbers at me.... thanks aganin
Old 08-09-2010, 09:28 PM
DoubleVision's Avatar
The comp cams high energy 268 will serve you fine.
It`ll give you a slight lope at idle plus it won`t kill off low end torque.
http://www.summitracing.com/parts/CCA-12-210-2/
What cam to get with my current build? havin_a_ball Engine 17 08-05-2010 12:46 PM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 11:03 AM
I need cam help 355s10 Engine 5 03-16-2008 05:34 PM
Oddball Cam source? Biggarmike Engine 3 02-02-2003 10:52 AM
