Help, flexplate question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2003, 01:15 PM
Question Help, flexplate question
Swapping a powerglide for a turbo 350. Can I use the same flex plate?
Thanks!
Old 09-03-2003, 01:48 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
I'm no expert, but I think the flexplate has to match the motor, so you should be fine. As long as the converter bolts up that is...
Old 09-03-2003, 01:58 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
ditto what Kid with a wrench said.....
i think that the flex plates are the same for either tranny. but as soon as i hit 'post' some one will prove me wrong. rightly so.
Old 09-04-2003, 03:10 AM
Measure between the converter bolt holes to see if they match. There were more than one pattern for GM flexplates.
