Help forming body lines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2009, 09:32 PM
Hello I am new here and have a little bit of body work experience but not official training. I am recently repainting my 73 IH scout and have stripped the hood down to bare metal. Here is where I need help.
-When stripping the 10 layers of paint I noticed a layer of bondo over the rear half of the hood. So after it was stripped I tested to see how straight the hood was in that area with a straight edge, turns out it dips down maybe 2/16th in that area all the way across the hood so I used bondo and got it level again. HOWEVER, there is a slightly raised line that runs down the middle of the hood and it is now under a layer of bondo at the rear half of the hood. So how do I go about reforming this raised line with bondo?????
-Or how should one do this and keep the raised body lines?????
Thanks,
I am lost and have been working on this hood the last 2 days help!!
Old 09-24-2009, 09:44 PM
milo's Avatar
point on positive
Masking tape, and then work one side of the line then the other ...
Heres a link to a thread that might help...
body line
Old 09-24-2009, 10:01 PM
RODDER18's Avatar
As Milo said masking tape and a few types of sanding blocks also you can make your own tools for tough lines to copy. Sand paper wrapped around a paint stick for sharp lines and around wooden dowels for curved lines. It does get easier with practice.
Old 09-24-2009, 10:06 PM
Thanks for the reply I will be giving this another shot tomorrow!!! The tape idea seems to be the way to go.....................
Old 09-25-2009, 07:41 PM
jaak923's Avatar
I use the tape method also...its great. Im just a hobbiest not a pro and a couple of other tips I have learned is 1. if you use 2 different color hardeners, say blue for top of the body line then red for the bottom it helps you see you work better. and 2. buy good masking tape to do this, the cheaper kind usually won't stick well, or if it does stick, when you pull it off it will leave residue behind.
Heres a pic using different color hardeners...
Good luck with your project,
Jason
Old 09-25-2009, 07:47 PM
Thanks for the advice guys, I was totally lost until trying the tape method. It works great!!!!!!!!!!
Old 09-27-2009, 11:49 AM
RODDER18's Avatar
Glad to help. You may also want to use a guide coat for finish sanding and blocking.
Body - Exterior "Tips of the Day" Jon Body - Exterior 11 09-07-2007 11:29 AM
Handbuilt aluminum body ckucia Body - Exterior 25 07-18-2007 12:15 PM
Pulling the body Rufus_2 Body - Exterior 8 01-15-2007 05:34 PM
32 Ford body, firewall and body bolts heyjude076 Body - Exterior 5 11-20-2006 05:57 AM
Hotrodders Knowledge Base: Body - Exterior Jon Body - Exterior 0 11-26-2005 06:33 PM
