HELP front crank seal for a 66 430 Conti - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2007, 03:50 PM
hello and thank you for reading
dose any soul have an idea where i can locate this part
dealerships dont carry this, nor dose the basic refraccionaria shops,
all parts shops are claiming that it is too big for a front crank
maybe they are not familiar with this curio of a engine block seal
for it is the first for me,
it is ready to go back in to the engine bay
all i need is some direction of locating the seal
the seal is placed on rim of the hole front of block
then covered by the power stearing pump
dimensions in Standard Inches
full diameter is aprox 3 5/8
inlet diameter is aprox 2 7/8
surface of the the seal is 2/8
sleve lenght is 3/8
with a lip 1/8 around
on the seal surface the is a number sequence in a triangular position
of
IR 25
B9ME-3A586-A (is this a 1959 part?)
and the Oval FoMoCo
thank you again for your time and help
Old 06-02-2007, 05:14 AM
aka Duke of URL
-BEST GASKET- is the only source I know of for a quality replacement seal. FEL-PRO does not make one.
Also be aware the pump is held to the front cover with specialty fasteners-
-DISCUSSION of CRANK DRIVEN PS PUMP-
B9ME is 1959 MERC. This style pump was first used on 1958 MEL production.
A 66 LINC should have a 462 and C6.
-Mercury-Edsel-Lincoln- Engine Forum
Last edited by 68NovaSS; 04-24-2012 at 08:07 AM. Reason: Profanity. Please see: general board guidelines.
66 impala front brakes starliner Suspension - Brakes - Steering 6 08-15-2012 07:04 AM
66 Mustang front suspension upgrade 66StangBoy Suspension - Brakes - Steering 26 01-02-2007 04:32 AM
66 impala front brakes starliner Suspension - Brakes - Steering 7 04-29-2005 01:49 AM
Front seal, small or large ? Rad Ray Engine 3 12-08-2002 02:31 PM
350 front seal oil leak buddy Engine 4 08-29-2002 05:25 AM
